Cognizant
PRPC 7.1.9 # pzCanPerformAssignment returns TRUE where a FALSE is expected
Post upgrade from PRPC V6.2.1 to V7.1.9 we observed an authorization issue only in UAT environment. We have thoroughly tested the relevant scenario in ‘DEV/QA/Performance’ environments and it could not be reproduced.
Our observations in the following sequence below...
- User clicks on an assignment that belongs to a restricted case to which he/she has no access (configured via access roles)
- On-click event triggers the OOTB Rule-Obj-Activity OpenAndLockWork
- OpenAndLockWork calls the OOTB Rule-Utility-Function pzCanPerformAssignment
- pzCanPerformAssignment verifies the relevant Rule-Access-When CanPerform (Customized to meet our client requirements)
- OOTB PRPC function pzCanPerformAssignment is returning TRUE while we were expecting a FALSE.
- Now; the user can access any case that belongs to any restricted work group.
Our client is worried about what might happen in production after the Pega7 go-live date.
Solutions attempted so far in UAT...
- Revalidate & Save relevant Rule-Access-Role-Name/Rule-Access-Role-Obj(s).
- Create the Rule-Access-When with new option in DEV and move it to UAT.
- Clear Assembly/Rules cache from SMA.
- Recompile the concerned function & library.
- Truncate Pega7 cache tables and restart JVMs along with deletion of PegaRULES_Extract_Marker.txt
- Compare application stack and verify environment specific rulesets for conflicts.
- Enable relevant logging.
