Pega 7 CMIS/atom integration with Alfresco Community Edition 5.0
I'm trying to configure CMIS integration over atompub with Alfresco Community Edition 5.0 but I'm having problems.
My environment:
Pega 7 instance is ML7 personal edition running locally on my laptop.
Alfresco Community 5.0 is also running locally on my laptop.
I used the Alfresco Community Win 64 installer - creates separate Tomcat/PostrgreSQL instances as Windows services so I used Advanced mode to change all the ports from the defaults so there is no conflict with the ones used by Pega 7.
I can log into Alfresco and create a site and documents using the web tool that ships with the product so I have every reason to believe that the install is good.
On Pega I created an atom server instance. However the Test Connectivity button gives me a Fail.
I checked that the two Windows services (one for Tomcat and one for PostgreSQL) are started - they are.
The URI that I am using is:
http://127.0.0.1:8090/alfresco/api/-default-/public/cmis/versions/1.1/atom
(I have also tried localhost instead of 127.0.0.1 in case it makes any difference but it doesn't)
This is the URI that the Alfresco documentation website says to use for version 5.0 (the URI you have to use is different for each version of product).
The Fail on testing connectivity contains the following text:
Status fail
Message com.pega.apache.axiom.om.OMElement.setFirstChild(Lcom/pega/apache/axiom/om/OMNode;)V
Operator ID mccar1
Requestor ID H2B599A71C357B27187467E740D5C2DA5
Timestamp Thu Sep 10 10:39:34 BST 2015
Engine Version PegaRULES 7.10 ML7 (coreAssemblyCached_717_644)
Interestingly if I try the URI specified by Alfresco for use with version 3.x I get a different error:
Test Connectivity For Data-Admin-Connect-AtomServer.AlfrescoServer
Overall Result
Fail
Couldn't connect to Atom server located at http://localhost:8090/alfresco/service/cmis <p> 404-Not Found
List of Steps
Step Result
Establish Connection to Atom Server Fail
Get Service Document Not attempted
Components Tested
Description Value
atomServerUserID admin
atomServerURI http://localhost:8090/alfresco/service/cmis
Response
Response
Has anybody else tried this configuration? How did you get it working?
Rob
