enter a past date
to validate a control field what is the best method?
date control or edit validate?
Can you please give us a little context? Which lesson/course are you busy with?
Miki
You can use validate or edit validate rule.
Depending on the property type, you can:
Damien
There is no edit validate rule called IsPastDate but there are some edit validate rules such as: pyIsPastDate and NotFutureDate which will come under the same scenario.
Mounica D
Hi Nirmal,
Better option is to go for edit validate. Because in case you give a date control and in the UI you do not enter a date ( in case it is not required) then a default date of 1970 is displayed.
