    QBE
Data Only Update failing from 7.1.9 to 7.2.0
Data Only Update is failing from 7.1.9 to 7.2.0 with below exception. Database being used is MSSQL.
Note: We are also having CPMFS 7.14 in our system.
Steps Followed:
1) Migrated Rules from 7.1.9 Rules to new Schema 720 Rules - Success
2) Updated Rules in New Schema 720 Rules - Success
3) Run Rule Schema Object Generation (Migrate Script) - success
4) Update Data Only True - Failed with below exception.
[java] Feb 19, 2016 3:46:21 PM com.pega.pegarules.internal.bootstrap.PRBootstrap
     [java] SEVERE: Problem during method invocation (main)
     [java] com.pega.pegarules.pub.database.DatabaseException: Database-General    Calling getDataUniqueID    8114    S0005    Error converting data type varchar to datetime.
     [java] DatabaseException caused by prior exception: com.microsoft.sqlserver.jdbc.SQLServerException: Error converting data type varchar to datetime.
     [java]  | SQL Code: 8114 | SQL State: S0005
     [java]
     [java] From: (unknown)
     [java] Caused by SQL Problems.
     [java] Problem #1, SQLState S0005, Error code 8114: com.microsoft.sqlserver.jdbc.SQLServerException: Error converting data type varchar to datetime.
     [java]     at com.pega.pegarules.data.internal.access.DatabaseImpl.getDataUniqueID(DatabaseImpl.java:8105)
     [java]     at com.pega.pegarules.deploy.internal.util.InstalledHotFixMgmtImpl.saveMLDataRollbackInformation(InstalledHotFixMgmtImpl.java:383)
     [java]     at com.pega.pegarules.deploy.internal.archive.commands.NonRuleResolvedRollbackStateSaver.saveMLRollbackInfo(NonRuleResolvedRollbackStateSaver.java:128)
     [java]     at com.pega.pegarules.deploy.internal.archive.commands.NonRuleResolvedRollbackStateSaver.finish(NonRuleResolvedRollbackStateSaver.java:135)
     [java]     at com.pega.pegarules.deploy.internal.archive.importer.DataUpgrader.afterDeploy(DataUpgrader.java:53)
     [java]     at com.pega.pegarules.deploy.internal.archive.importer.AppBundleHandler.deploy(AppBundleHandler.java:97)
     [java]     at com.pega.pegarules.deploy.internal.archive.importer.DataUpgrader.runUpgrade(DataUpgrader.java:66)
     [java]     at com.pega.pegarules.deploy.external.util.UpgradeUtil.main(UpgradeUtil.java:73)
     [java]     at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
     [java]     at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
     [java]     at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
     [java]     at java.lang.reflect.Method.invoke(Method.java:497)
     [java]     at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370)
     [java]     at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411)
     [java]     at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224)
     [java]     at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:273)
     [java]     at com.pega.pegarules.pub.PegaRULES.main(PegaRULES.java:85)
     [java] Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: Error converting data type varchar to datetime.
     [java]     at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:216)
     [java]     at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1515)
     [java]     at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.doExecutePreparedStatement(SQLServerPreparedStatement.java:404)
     [java]     at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement$PrepStmtExecCmd.doExecute(SQLServerPreparedStatement.java:350)
     [java]     at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:5696)
     [java]     at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:1715)
     [java]     at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:180)
     [java]     at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:155)
     [java]     at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.execute(SQLServerPreparedStatement.java:332)
     [java]     at com.pega.pegarules.data.internal.access.DatabasePreparedStatementImpl.execute(DatabasePreparedStatementImpl.java:582)
     [java]     at com.pega.pegarules.data.internal.access.mssql.SQLGeneratorMssql.getDataUniqueID(SQLGeneratorMssql.java:922)
     [java]     at com.pega.pegarules.data.internal.access.DatabaseImpl.getDataUniqueID(DatabaseImpl.java:8091)
     [java]     ... 16 more
     [java]
     [java] Feb 19, 2016 3:46:21 PM com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega
     [java]
     [java] 2016-02-19 15:46:21,441 [                main] [          ] [                    ] (access.mssql.SQLGeneratorMssql) ERROR   - Unable to execute {call pega719_data.sppc_data_uniqueid_withouttran (?, ?, ?, ? ,? )}  S0005:8114
     [java] com.microsoft.sqlserver.jdbc.SQLServerException: Error converting data type varchar to datetime.
     [java]     ... 16 more
     [java]
     [java] Exception in thread "main" java.lang.RuntimeException: Problem during method invocation (main)
     [java]     at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:279)
     [java] Caused by: com.pega.pegarules.pub.database.DatabaseException: Database-General    Calling getDataUniqueID    8114    S0005    Error converting data type varchar to datetime.
     [java]
     [java]     ... 1 more
     [java]     ... 16 more
BUILD FAILED
C:\pega\pega72update\scripts\setupDatabase.xml:2235: Java returned: 1
Total time: 7 minutes 11 seconds
Exiting with Error
