Case Specialization
I saw the following sentence in Case Specialization lesson: "We can a circumstance-qualify a case type rule with a single property, a date range, or a property and date range."
I understand how you can specialize a case using Case Designer, Details tab and Specialization. My understanding is that you can use only one property in order to specialize a case and, after you did the specialization you are not able to change it but you can define more specializations based on it.
Also, I can see an option to specialize a case using Case Type rule from App explorer, Save->Specialize by circumstance, and here you have the option to chose a property - value and date property - date value pairs.
My question is: how can you specialize a case with date range or property and date range?
thank you
