Case Designer
Hi All
I am facing this issue in the case designer when changing the Step Type in Case Designer. I have attached the screen shots with the Details
Issues when I edit the Step Type from Single Step Assignment to Multi Step Process: Following errors :
- pyProcesses:** Test compilation failed: ---------- 1. ERROR in Rule_Obj_Flow_SAE_HRServices_Work_Candidate_DetermineTargetPosition_Action_20150518T064221_517_GMT.java (at line 159) bIsConnector = IsConnectorFlowAction_ASSIGNMENT63_circum0(strAction); ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ The method IsConnectorFlowAction_ASSIGNMENT63_circum0(String) is undefined for the type Rule_Obj_Flow_SAE_HRServices_Work_Candidate_DetermineTargetPosition_Action_20150518T064221_517_GMT ---------- 2. ERROR in Rule_Obj_Flow_SAE_HRServices_Work_Candidate_DetermineTargetPosition_Action_20150518T064221_517_GMT.java (at line 161) bIsConnector = IsConnectorFlowAction_Assignment1_circum0(strAction); ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ The method IsConnectorFlowAction_Assignment1_circum0(String) is undefined for the type Rule_Obj_Flow_SAE_HRServices_Work_Candidate_DetermineTargetPosition_Action_20150518T064221_517_GMT ---------- 2 problems (2 errors)
Althea
