Rabobank
Binary of flow rule not being checked in when flow rule is checked in Pega 7.1
We have an enviroment with Pega 7.1.7 and we have had two ocurrences that when people check in the flow rule the binary file of the corresponding flow rule is not being checked in and the flow gets locked.
The solution is to delete the checked out flow rule (Since it doesn't even show an option to check in the binary file).
I remeber this wasn't the behaviour of past PRPC versions, does anyone know is this is a new behaviour or if there's an article regarding this?
DSD Incorporated
Your question has been escalated to provide you with the appropriate technical support.
TSYS
We are also facing same issue in 7.1.6. Is there already a solution for this?
binary files and few other final, APIs & internal rules are skipped in rule search starting Pega 7.1.6.
not sure of any Hfix or any other resolution other than performing a delete checkout on the binary rule form.
note: binary rule forms are used at Application documentation wizard.
Services Australia
We are using Pega 7.1.7, but havent seen such issues any time with flow rules.
Could you check if the issue happening with other operators/rulesets with check in enabled and disabled / different application in your environment?
Vamshi
Rabobank
This has happened for us in multiple enviroments with different operators even when using pega cloud and no reply has been provided from pega at this point.
Services Australia
Strange. Let me try and get 7.1.6, currently i have 7.1.7
Vamshi
ACC3
Using Pega 7.1.8 for the Deutsche Telekom POC and we ran into this multiple times. Particularly during low-bandwidth situations when we were working onsite or at a hotel. The only solution we had was to "save as" then remove the rule, then "save as" another copy of the original name in order to be able to check in and out without issue.
What is most frustrating is that you click on the checkin button and it does the loading graphic for a second without throwing any errors.
Bank of Nova Scotia
Go to the Ruleset version where the flow rule is present. Now in the ruleset version open the "Checked out records" and then Open the Binary File. Now in the action simply click Release Lock. It will work.
The Flow can now be checked in and out without any issues.
ANZ
Thanks Pinaki this works
DXC technology
That's a nice solution for this binary file issue and it works perfectly.
Vamshi
ANZ
Hi Pega,
Is there any solution or hotfix provided for this issue. I am still facing the same issue in Pega 7.2.1
Mathi
