Last activity: 12 May 2017 13:13 EDT
Ask the Expert - Offline Mobile
ibm
hi
greetings
there is a requirment like we need to do calculation in differnt excels and need to b updated to application . those application hw could be done in openspan either through scripting??
is it possible that sap script works in openspan ?
for this requirment which decision will be taken .please updated me as soon as possible .
Thank you.
This comment has been branched out as a new node and the new thread can be followed here
Hi Ashok,
Thank you for posting your query on PSC. Your question looks to be related to Pega Robotics and this discussion is open for Pega Mobile capability questions. Therefore, we have created a new post for you: Robotics Requirement - Calculation performed in different excels to be updated into Application
Please continue the discussion over the new post.
Thank you!
Cognizant
#1# Among the following industries which will benefit the most by leveraging Pega's Offline capabilities?
Communications / Energy / Finance / Government / Healthcare / Insurance / Life Sciences / Logistics / Manufacturing / Media / Utilities
#2# Which functionalities of 'Pega field service' use Pega's Offline capabilities?
https://collaborate.pega.com/question/pega-field-service-details
#3# Do any of the Pega’s solution frameworks use Pega's Offline capabilities? (Such as 'Customer Service / Smart Dispute / Know Your Customer')
Mohammed Adil Saleem
PL
Offline capabilities lie at the base of the Pega platform and as such they are not strictly related with particular industries or frameworks. Potentially all industries could benefit from leveraging offline capabilities, most notably those that deal with mobility, low quality networks, or that operate in the out-of-range areas: logistics, utilities, energy, etc. Because Pega Offline support is very generic, application developers can leverage the capabilities wherever they find them applicable. Sales force automation, and field service are naturally the frameworks that benefit the most. They are currently being expanded to make use of various possibilities that Pega Offline gives.
#1 - As Radek has mentioned, Offline is not necessarily industry-specific. Anywhere you have a workforce that is often going into remote areas, or locations with unknown network coverage benefit from offline capabilities. Field agents, field services, visiting nursing, canvassers, inspectors, etc. all benefit. Offline solves a logistics issue that is common to all of the industries you listed.
#2 - You should visit https://www.pega.com/products/crm-applications/field-service as it has a lot more content that shows how mobile and offline is now an integral part of the Pega Field Service solution.
#3 - Several frameworks like Field Services and Sales Automation use offline as an integral part of their solution. However, Offline is integrated with Pega 7 at the core, so it can be used in combination with virtually any framework. For example, UnitedHealthCare successfully used Offline in combination with the Healthcare framework to greatly help their agents: https://www.youtube.com/watch?v=5zhlz9L6IxQ
Did You Know?
Pega 7 mobile applications (apps) can use offline capability when running on a mobile device. Enabling this feature for an application means that when the app is running on a mobile device that is offline (as in, a connection with the server is lost or not available), you can still perform the following tasks:
- Create a new case
- Complete any of the assignments listed in your worklist
Understanding offline
For Pega 7 mobile apps built with offline capability, an online and offline rendered version of a user case portal is available.
Did You Know?
- Create a new case
When your mobile device is offline, and you attempt to open or submit an assignment or to create a new case, all steps are saved in the data store. When the network connection state changes and the mobile device comes back online, data synchronization is triggered automatically for the app, and any saved data is updated to the server using the store and forward capability.
When your mobile device is online, completing an assignment or creating of a new case means that any changes are immediately submitted to the server using the online version of the case portal. The store and forward capability is not leveraged in this situation. However, if mobile device goes offline at any time, app information is saved in the data store using the data and forward capability.
Important behavior
Only single-step assignment processing is supported for the offline capability in mobile applications. This means that after each completed assignment in the case when working offline, the app's end user (or a user on another device) must first go online to continue to the next step in the case. It is not possible to perform more than one assignment in the case when in offline mode.
To successfully use offline capability, a mobile app end user must successfully log in to the server at least once. Only after the initial login takes place, can offline capability be leveraged with the mobile app.
Configuration note
When building the application, enable offline capability and choose optimistic locking in the case type settings. Additionally, when configuring an application to use offline capability, remember that a portal based on the Case Worker portal (such as pyCaseWorker) must be set as the default for every access group whose users will be accessing the application.
*Taken from Mobile offline capability - Pega 7.1.7
How many of you have made use of the client clipboard?
Were you aware that in 7.1.9, a mobile clipboard viewer was introduced for iOS? By building a iOS debug version of your mobile application, you get access to debug features through the mobile device. This can be very helpful in tracking down issues.
Also, have you discovered the "Sync issues workbasket" configuration for offline-enabled Case Types?
Under the General setting tab for a Case Type, if your case is enabled for offline, then you have the option to specify a workbasket. For offline, all of the work is stored on the the device and replayed on the server when it is available. By specifying a workbasket in this field, should any work items encounter errors during replay (validation, locks, etc.). The work object will be saved with the errors and routed to this workbasket. This allows you to open and repair the work items on the server, without the mobile user having to do anything on their part. This can be extremely helpful in certain circumstances.
If you have questions or suggestions about troubleshooting and recovery, now is a great time to ask those questions and give us your feedback. You want to make sure you are prepared for such eventualities before you go into production.
- James
L & T Infotech
How To Send data From one window form To Another window Data Grid View form
Hi Raghavendra,
I am not sure if this is a Mobile/Offline question or not? In Pega, data exists in either the form, the clipboard or the database. The same is true for Offline. If you do a refresh section that has submit enabled, the data moves from the form to clipboard. If the other section refreshes as well, it will pull the data from the clipboard. This capability exist in Offline as well. However, for offline, you should use a Repeating Dynamic Layout instead of a Grid. I hope this helps.
- James
Hi Folks,
I have a question related to Mobile touch id authentication on ios. we are using Pega Cloud ver 7.2.2 and have a custom mobile application for ios. We are unable to get touch id work even after enabling Dynamic System Setting for Touch ID.
Any clue of specific settings that we need to run-pass?
PL
Here is the checklist that you have to follow in order to make it work:
- Make sure the Dynamic System Setting for Touch ID is not set to "false". See: https://community.pega.com/sites/default/files/help_v722/procomhelpmain.htm
- Enable and configure Touch ID in the operating system's settings. Make sure either "iPhone Unlock" or "iTunes & App Store" is turned on:
- Log in at least one time using regular credentials (user name and password) and make sure the "Remember me with Touch ID" checkbox is checked on the login screen.
- Make sure the Web-Login rule has not been overwritten with a version that has no or wrong references to required JavaScript files, and that Touch ID sections were not removed from it. If you customized Web-Login, make sure you based your work on the appropriate version (7.2.2 in your case).
I hope this helps.
Hi RadoslawNowak, thanks for your response! I have verified the settings on iPhone and DSR to ensure they are as required. Also verified fingerprint scanner is working on iPhone independently.
User Interface expert has updated the style in Web-Login but have not removed any sections. I have also verified that pyWeb-login-mobile-touchId.js is being refereed in <script> tag and it does exists in system.
Any other setting /reference that might be worth checking?
PL
The checklist was complete. To investigate it further, I would need access to your environment. If you could send the details to me by e-mail, I'll help you diagnose the issue...
Accenture Technology Services
Hi Folks - Appreciate your help on the below points :
1. Is there any way in Pega mobile to disallow jailbreak devices ?
2. Is there anyway to prevent backup and copy of the mobile data to removable storage (SD)?
3.Is the default session timeout for xx minuted of inactivity is true for mobile app also ?
4. Any recommended simulator for testing hybrid apps while the actual device is not available. I am aware of Chrome and Safari browsers for testing.
5. Client plan is to use a generic MDM and not AMP Manager to distribute the hybrid app . Do you foresee any issue with that . Any recommended steps will be very helpful here
6. External authentication in the Pega 7 Platform work on a mobile device . How it will be if the same user tries to login when in offline mode.
Thanks in advance :)
PL
Let me reply to your questions one after another as I have to look here and there to collect all the information.
So for question #1, the answer is "no". The nature of a jailbreak is that you can do virtually anything there, so you can modify it in such way that it adapts to any fancy mechanisms in our application that we could introduce in order to prevent that. In practice, applications can be equipped with such mechanisms that discover popular jailbreaks, but if someone (with bad intentions) purposefully would like to let our application work on a jailbroken device, then he could simply do it with a little skills.
PL
For question #2 there is no such way in the mobile app. But please remember that such a copy is useless without the original device and user's credentials because the data is always encrypted in Pega mobile apps. What is more, many operating systems (specifically all modern iOS devices and some Android ones) use the additional system-level encryption.
PL
For question #3, the answer is "yes". If a user tries to perform any action after that time, he is logged out and prompted for password.
PL
For question #4, simply use the simulators delivered with development tools for given platforms: with Xcode for iOS and with Android SDK for Android.
PL
For question #5, there should be no issues with using a third-party MDM for distributing Pega mobile apps.
PL
For question #6, although Pega Mobile Client supports all external authentication schemes, not all of them will work with offline-enabled applications. The only scheme that will work is when Pega server serves as a kind of a "proxy" to the external authenticator. In such case the mobile app gives credentials to Pega server (through the regular Pega login page) which passes them to the external server for the actual authentication and returns the result to the client.
Thank you so much @Nowar
Thank you for the great session! Special thanks to our Experts - Stephanie, James and Radek for being fantastic. We will be closing this discussion. Any questions, Write a new post!
Thank you!
