Access When Rule is not resolving class properties
I've created an access when rule that I'm using in the access manager to conditionally control modify privileges to a case type. The access when rule is applied to the class CW-FS-Work-FSR however when the rule is executed it is not resolving a property in the CW-FS-Work-FSR class. I am certain the access-when rule is being used to control the modify privileges because if I set the access when to 1=1 and change the bit (using NOT) then access is granted/denied to the work item.
I've tried adding appropriate Page Names to the Pages & Classes tab to help in resolving but have had no success.
Am I missing something obvious in getting the property to resolve in the access when rule?
