Catcos
PK
Last activity: 29 Feb 2024 9:06 EST
How to Use Signature Capture in Constellation?
Hi there,
In one of my projects, I need to use signature capture. However, they use the PEGA constellation, so we cannot add signature capture as a field type. Despite having signature capture, we cannot use it in case views.
Is there anyone aware of this?
@SyedAhsanA9162 Signature capture is not available OOB but can be built as a Constellation DX component - We have worked on providing a gallery of Constellation DX Component at https://github.com/pegasystems/constellation-ui-gallery - There is a complete and functional signature control component - the repo even has a RAP that you can import that will have a pre-built version of the component that you can use as is on a 23.1 system. If you are on an older version, you can fork the repo and build from source - the repo is open source with Apache 2 license.
https://pegasystems.github.io/constellation-ui-gallery/?path=/docs/fields-signature-capture--docs
https://github.com/pegasystems/constellation-ui-gallery/releases
