Pega Deployments for Pega'25 version
Now we are on Pega 8.8.1 and Infra Team is preparing the road map for next Pega upgrade to Pega'24.2 or Pega'25 and they came across the changes in Pega infrastructure like Deployment architecture point of view & Externalized services .
For now, Application servers are running in on-premises window machines, so Does Pega'25 Docker Image support the Kubernetes on Windows ?. Is there any limitation being in windows servers ?,
Is it possible to view the system requirements/resources needed for Pega'25 ?.
@BRAHMESH@ The OS of the host system generally shouldn't matter, as long as you can run the Pega docker images which always use Linux. This question and others is addressed at https://support.pega.com/support-doc/pega-infinity-deployment-changes-faqs#Kubernetes.
We have not published a roadmap for Pega '25 yet other than the fact that Kubernetes combined with Pega docker images built with Tomcat & Linux will be required for all deployments. But if you have specific questions about it we could provide guidance.
