IBM
CN
Last activity: 1 Jul 2023 4:54 EDT
Flow drawing: Hard to adjust connector direction
Refer to below pic:
the flow: As is: the "false" connector of 1st decision box is in location 1
To be: I want to change this connector to location 2.
After I drag end point to show dotted line in location 2, once I release my mouse button, it's still in location 1.
May I know how to adjust this? It appears so hard to adjust the connector direction/location in flow design.
Hi @MaxonL16591286: I don't see a limitation in the system to do this. Once you hover over the decision shape, you can create connector for it's edges and can connect to the other shapes. If you want to change the existing connectors, click the appropriate small white circles to move it to the required edge. Please also try to adjust the location of the shapes.
I hope there is no functional issues in your current diagram. Please let us know if you are facing any functional issues.
Thanks.
