Techmahindra
Last activity: 31 Mar 2023 11:24 EDT
"Start process injected C:\Program Files (x86)\Google\Chrome\Application\chrome.exe failed"
Hi Team,
I have print dialouge in my requirement , so I have started the process with window adaptor , it is working fine in 2012 VM environment , where as in 2019 VM environment , failed to launch the chrome browser.
Error message : "Start process injected C:\Program Files (x86)\Google\Chrome\Application\chrome.exe failed"
@VenkatKancham
We don’t recommend using a Windows adapter with Chrome (or Edge). You should be able to handle the print dialog natively is you are using 19.1.98 or greater. I would suggest getting the latest version of 19.1 however (or even 22.1 if you can).
https://docs-previous.pega.com/pega-rpa/automating-dialogs-chrome-and-edge
