ConnectionProblem Flow
Can anyone share a scenario where Connection Problem flow can be used for Error Handling in a connector, Instead of the response Data Transform?
***Edited by Moderator: Pooja Gadige to change category from General to Product, add product details tag, add platform capability tags***
@CDS07 When the response to be returned by the connector is not immediately needed for further processing, consider using an error handler flow. Please remember that The error handler flow is not executed if the error is detected in the response data transform or in a transition in an activity.
