Independent Consultant
BR
Last activity: 25 Feb 2021 11:13 EST
Field Value is not being applied as a caption/label in some controls
Somebody can help me with this issue? We have some controls for example check box, that we are using field value as caption/label to be able to make internationalization later. But for some reason that we dont know why, the text for this field value is not being shown. It shows the name of the field value itself like the way bellow:
The first one is with the field value, the second one it is a text value typed straight to the caption (that´s is the only way we could make it work)
The field value it is created in the same class as the section it is being created. For some other controls the field value works fine, but for this one for example and tab group also it doesnt work at all.
Any ideas on why?
@mario.mesquitaplease check that you are using the following configuration
1/ make sure that you are using a caption in your checkbox
2/ click on the rule opener next to the checkbox caption input field - it should create a FV of type pyCaption.
3/ at runtime, the FV should be picked up as expected
