Virtusa UK Ltd
Last activity: 1 Apr 2019 4:55 EDT
Opening a link in Modal Window
Hi
I have a link to an external UI application (non-pega) which I need to open in a Modal Window on click of a link. I am reading some of the other posts where openUrlInDialog or window.showModalDialog will not work in some of the browsers. Also I can see openUrlInDialog is deprecated. Is there a way I can launch the external application in modal window? I have to use modal here because I wanted to refresh the parent window with some service calls once the modal is closed.
Please suggest if there is a way to achieve this.
Ganesh
Hi Ganesh,
When we open a modal dialog then the submit and cancel button will be there associated with it.
So if you want to open any extenal app then you might go with opening it in a new window or tab by using the openURLinNewWindow API.
