ORA-01460: unimplemented or unreasonable conversion requested | SQL Code: 1460 | SQL State: 72000 while sending data in mail
Hi ,
i am getting the below error while calling OOTB SendEmailNotificationWithAttachments
** Caught com.pega.pegarules.pub.PRRuntimeException: caught DatabaseException while trying to open conclusion Property!UESDBBQACAGIAHGDPKGAAAAAAAAAAAAAAAATAAAAW0NVBNRLBNRFVHLWZXNDLNHTBLWWY27BMBBFF0XGTRDOZBEEHEUSKNAZBOGLDEUTI4SIHWI5SUS/70IKHDSR3JE5MWTEO7XNHHSGZU1RTFYMIWRVCNARR1KGTNQL3AFG33DFV9CSIYICESY7KNGRIRVZBNBHGMJGTS4WREKSP3MEZQVWXNZX4EGPFBAC6W848FRIJ3EAFRLEX3HPHYLDFXZ7SO3MDKRRGMY+TLQ8CFRODCTUB2OXVTCEFNM/ZMDLAPJ4RKTUT: There was a problem getting a list: code: 1460 SQLState: 72000 Message: ORA-01460: unimplemented or unreasonable conversion requested
DatabaseException caused by prior exception: java.sql.SQLException: ORA-01460: unimplemented or unreasonable conversion requested
i have a scenario like get the data from WorkattachFileclass and send that data in mail.
i follow the steps in activity
1.) get the data from WorkAttachFile (pyAttachStream contains actual data)
2) set the value of pyAttachStream property of WorkAttach-File class to pyReference property of Data-EmailAttachments class
3) open the Data-EmailAccount class
4) Call the OOTB activity SendEmailNotificationWithAttachments by passing Data-EmailAttachments page as parameter to SendEmailNotificationWithAttachments
Pls give me suggestions/ideas to fix this issue its very urgent
Thanks For help.
Pramod
Hi Pramod, Good morning!
ORA-01460: ORA-01460: unimplemented or unreasonable conversion requested tips
could you please refer the activity once & share your observations, Thank you!
psahukaru
