ING Belgium SA NV
BE
Last activity: 10 Jul 2025 10:12 EDT
Defer queue item from its activity
We use queue processors to handle micro services. For the error handling we set the activity status to fail in order to make use of the ootb retry mechanisms.
After x retries returning an error, the item is deferred to the broken queue items.
Sometimes you already know the first time an error occurs, it cannot be resolved by just retrying later. In this case, I would like to be able to just mark the item to be deferred without executing the retry mechanism as it would save time and processing energy.
Is there an easy way to obtain it. E.g. by setting some property or parameter in the activity?
Kind regards,
Joris
@Joris Claus
You maybe try to change the retry count to your max count limit , so that it will directly go to broken queue.
But as that is a static configuration in QP, not 100% sure if you can directly update it from your activity or not. You can check once.
