Help with Configuring Embedded DocuSign Signing in Pega
Hi Pega Community,
I’m working on integrating embedded DocuSign signing within a Pega case. I understand that to enable embedded signing, I need to set the clientUserId in the envelope recipient definition and then call the Recipient View API to generate the signing URL.
Has anyone successfully implemented embedded signing inside Pega? Any advice or pointers to Pega-specific documentation or examples would be really helpful!
Thanks in advance.
@NancyA72 please check if this helps Docusign in pega
From pega side you just need gets the data from the user and populate to the docusign properties like recipients, eventnotifications etc and hit the api.
