Schroders
Schroders
Schroders
Posted: Mar 21, 2025
Last activity: Mar 31, 2025
Last activity: 31 Mar 2025 8:36 EDT
AI Assistant - CK Editor
I would like to integrate the AI Assistant of CKEditor into the Rich Text Editor (RTE) field of our PEGA application. Has anyone successfully implemented this functionality?
@RajatK17297149 as the solution would require access to an external AI service and the use of a very specific CKEditor version, I don't think it is currently possible.
Jquery and ckeditor library versions in 8.7
@singk3 do you know who is responsible for CKEditor/GenAI features?
CKEditor AI Assistant Overview
CKEditor AI Assistant is a premium feature of CKEditor 5 that provides AI-powered capabilities within the text editor. It supports integration with three AI service providers:
The integration requires:
Integration Considerations
To integrate this with Pega's Rich Text Editor field, you would need to:
Current Community Status
Interestingly, I found that another Pega user posted the exact same question in the Pega Support Center about a week ago, but it hasn't received any responses yet. This suggests that while there's interest in this integration, there may not be many (if any) documented implementations available at this time.
Next Steps
If you'd like to pursue this integration, I would recommend:
References:
