IBM India
Last activity: 9 Jan 2025 9:31 EST
Custom Filter in report definition issue with drill down column menu summarization.
My. Requirement is:
- While loading report must show last 60 days data. after that user can choose date range max of 60 days different (I am using custom filter for UI). - My filter on main report is : (A and B and C) OR A AND D (Where A is product from custom filter , B start date from custom filter, C end date from Custom filter, D is report filter = less than 60 days) - I am getting last 60 days data while loading report and getting data base on custom filter if user change date range. - I have drill down report which also show correct data.
- Issue is when i apply column menu summarize on drill down report its showing result on default report data not on customer date range data.
