Mence Mobile
Last activity: 23 Sep 2024 3:52 EDT
Approval Automation's View Problems
I have a problem about my case type in trial instance. I added an approval automation to my case and configured it's view. However, I couldn't see the view when I run the case. I checked pega logs and tracer logs when I run the case. I found a few different errors. You can find these logs below;
ERROR pega-pega-6cc949665b-89dhn| Proprietary information hidden|Rest|application|v2|assignments_var12b5f58fa4512b8ca5f13d80b6d74688|ABFD6DAAE4B712B35A7E209ACB9308188A ABFD6DAAE4B712B35A7E209ACB9308188A - JSON web token is rejected during signature verification due to bad signature : Expired JWT. ;
Tracer Log: Unable to open an instance using the given inputs: pxObjClass = "Rule-HTML-Section", pyClassName = "MyOrg-FW-IKUCommon-Work-RenewalRegistration", pyStreamName = "Studentasses"
Can you help me how to solve this issue,please?
Selem
