Adqura
Adqura
Adqura
Posted: Sep 4, 2024
Last activity: Jan 9, 2025
Last activity: 9 Jan 2025 10:37 EST
how to check the segment size?
To check the segment size in Pega Customer Decision Hub:
For more detailed metrics, you can use the Performance tool or Admin Studio to analyze the Clipboard size, which indirectly affects segment size.
you can review the segment history information. Click on Audiences Segments and then click the name of a segment. Navigate to the History tab. For criteria segments review statistics about the current segment run in the Current run section and about previous segment runs in the Segment Statistics section. For list segments review details about previous uploads of files with customer data records in the Import History section.
Reviewing segment history Information
Using the Clipboard tool > Using the Tools menu
