The following video will demonstrate how to request a docker token from My Pega.
Video Transcript
0:01
0:05
Be aware that the process for requesting a docker image has changed.
0:09
In the past, users were issued docker keys.
0:12
Moving forward it users will be issued docker tokens.
0:15
This is a more secure way of giving access to docker images and necessitated based on upcoming changes to Artifactory.
0:23
In conjunction with this change, the user experience on my Pega is changing too.
0:28
It will be updated to allow for end users to better manage their Docker tokens.
0:32
This includes the ability to to request older versions of Docker tokens with a proper approvals from Pega.
0:39
If you need a quick refresher on Docker images, users can request access to Pega provided image repositories to download Docker images, which are required for Pega platform deployments.
0:51
Pega provides access credentials only to clients that have the appropriate support role within their organization.
0:58
Pega partners are not allowed to request an access token on behalf of their customer to obtain the Pega provided Docker tokens.
1:06
With that said, let's walk through the steps for requesting a Docker token on My PEGA.
1:12
This can be done by logging into my.pega.com.
1:15
From the main navigation, you can click Software and then My Software.
1:23
The page you land on will contain 2 tabs.
1:26
The first tab is intended for downloading entitled Software Product Images, while the second tab, Docker Tokens, will allow you to request and manage your Docker tokens.
1:35
Click the Docker Token tab.
1:40
If this is the first time visiting the page, you'll see a button labeled Generate Docker Token.
1:46
Click that to initiate your request.
1:50
Review the confirmation message and click Submit to proceed.
1:56
You'll then see a message that the Docker token was successfully generated.
2:00
You will need to access your e-mail in order to obtain the necessary credentials.
2:06
Within the body of the e-mail you just received, you can access the Docker token, which can be used to login to Pega Docker image repository to download the image.
2:18
Now let's take a look at how to request a Docker token for an older version of PEGA software.
2:23
Navigate back to my PEGA.
2:26
Once you refresh the screen, you will now see you you will have an option to regenerate a docker token or to generate a token for an older version of PEGA.
2:42
Click Generate a token for an older version of PEGA software.
2:48
This will open a modal where you have the ability to select from prior versions of PEGA software, for example 85 or 84.
2:56
Once you make your selection you can then select from Patch releases Proprietary information hidden.4.
3:05
Once you make your selection, you then provide a description for why you need this version of software and click Submit request to proceed.
3:25
Your request will then be routed for approval.
3:27
If your request is approved, you will be notified by e-mail.
3:31
Refreshing the screen, you'll see the status of the request updated from pending approval to active.
3:42
You can now follow the same steps from the e-mail to retrieve the docker token, which you can then use to log into Pegas Docker image repository and download the image.
3:54
We hope this video is helpful in understanding the new docker token experience on my Pega.
3:58
Thank you.
@KimOsbourne Generated token is it valid for certain duration/time or generate once & use it any time.
