Symptoms
After upgrading to Pega Infinity 25.1.1 or 25.1.2, database table usage data is not available in the Tables tab on the System resources > Database landing page in Pega Diagnostic Center (PDC).
Errors
The following warning message is displayed:
Warning. Push DB Table Usage Data Information agent that feed tables data to PDC stopped running since <date>.
Environments
The problem occurs on Pega Platform versions Infinity 25.1.1 and 25.1.2.
Solution
To resolve this issue, perform the following actions:
Install the updated product rule component
- Download the product rule component for your Pega Platform version. The versions are listed in the RAP Matrix table.
- Use the Import wizard to install the product rule component. Ensure you use a secured login URL, for example, https.
For more information, see Importing Rules and data by using the Import wizard.
RAP Matrix
The enhanced PushDBTableUsage product rule component is available for the following versions of Pega Platform:
