Issue
After updating Pega Platform™ to ‘23.1.5 or ‘24.1.5, environments that use embedded Elasticsearch might experience SSL handshake errors when Apache Tomcat starts. Search functionality becomes unavailable.
Symptoms and Impact
Search indexing and search results are unavailable.
The logs contain the following exception:
javax.net.ssl.SSLHandshakeException: (certificate_unknown) Hostname or IP address is undefined
Caused by:
java.security.cert.CertificateException: Hostname or IP address is undefined
SearchGuardSSLNettyTransport can also return:
SSL Problem Hostname or IP address is undefined.
The pyFTSIncrementalIndexer Queue Processor has a Not running status, and retrieving Elasticsearch shard information can return:
Can't retrieve Cluster Shards Info.
The issue affects Search Indexing and records the same SSL handshake, Queue Processor, and shard-information symptoms.
Steps to Reproduce
- Update a Pega Platform environment to Pega Platform '23.1.5 or ‘24.1.5.
- Perform search and observe that results are not retrieved.
- Check the status of pyFTSIncrementalIndexer Queue Processor.
- Result: It is in Not running state.
- Fetch the shard details using steps discussed in How to gauge the health of the Elasticsearch cluster and shards.
- Result: The following error is displayed: Can't retrieve Cluster Shards Info.
Root Cause
The issue is related to the Elasticsearch node's SSL certificate not containing a valid Subject Alternative Name (SAN) or Common Name (CN) that matches the configured hostname or IP address, which is causing the SSL handshake to fail upon Tomcat restart following the patch application.
Recently Pega plaform io.netty jars were upgraded from version 4.1x to 4.2x as part of Pega’s proactive security strategy. In the updated version, hostname and IP address validation have become mandatory, which is not currently supported by the out-of-the-box Pega search Elasticsearch certificates.
The errors are only seen by users running Embedded Elasticsearch, which has been deprecated and replaced with externalizing search via the Search and Reporting Service (SRS).
Solution
To support a safe and well-supported route to Pega Platform '23.1.5 or 24.1.5 follow the steps below. These are the keytool Commands to generate es-keystore.jks and es-truststore.jks
To generate the keypair, add comma-separated IP addresses or DNS names of all nodes that form the cluster with the search nodes (web node, background/batch node, and search node).
Steps to Generate es-keystore.jks and es-truststore.jks
1. Generate Keypair
Use the following command to generate a keypair:
keytool -genkeypair -alias es-cert -keyalg RSA -keysize 2048 -validity 3650 -keystore es-keystore.jks -storepass <PASSWORD> -keypass <PASSWORD> -dname "CN=<FQDN>, OU=<ORG_UNIT>, O=<ORG>, L=<CITY>, ST=<STATE>, C=<COUNTRY_CODE>" -ext SAN=dns:<FQDN>,dns:<SHORTNAME>,dns:*.example.com,ip:<IP_ADDRESS>
Sample Command:
keytool -genkeypair -alias es-certlatest -keyalg RSA -keysize 2048 -validity 3650 -keystore es-keystore.jks -storepass <password> -keypass <password> -dname "CN=PegaSystems Worldwide Limited, OU=PegaSystems Worldwide Limited, O=PegaSystems Worldwide Limited, L=Hyderabad, ST=Telangana, C=IN" -ext SAN=dns:xxxxx.rpega.com
2. Convert JKS to PKCS12
keytool -importkeystore -srckeystore es-keystore.jks -destkeystore es-keystore.jks -deststoretype pkcs12
3. Export Certificate
keytool -exportcert -alias es-cert -file es-cert.crt -keystore es-keystore.jks -storepass <PASSWORD>
4. Import Certificate into Truststore
keytool -importcert -alias es-ca -file es-cert.crt -keystore es-truststore.jks -storepass <PASSWORD> -noprompt
Result : es-keystore.jks and es-truststore.jks will be generated successfully.
Steps to Update Keystore and Truststore in DevStudio
- Login to DevStudio.
- Navigate to: .
- Open es-keystore.jks.
- Click , select the latest es-keystore.jks file, and click Save.
- Repeat the same steps for es-truststore.jks:
- Open es-truststore.jks.
- Upload the latest file and click Save.
- all nodes after performing the above changes to apply the updates.
Reference
Pega Platform Infinity 23.1.5 Installation and Update Information
Pega Platform Infinity 24.1.5 Installation and Update Information
Pega Platform 24.1.5 Patch Update Impact
pyFTSIncrementalIndexer not running or turning off automatically
