Issue
When updates are made to a work object, such as submitting an assignment, users encounter unexpected authorization errors that occur against unrelated assignments. This issue occurs after updating to Infinity’ 25.
Symptoms and Impact
Errors
- You are not authorized to open instance ASSIGN‑WORKLIST‑XXXX
- You are not authorized to create, modify, or lock instance …
Steps to reproduce
- Update to Infinity’ 25.
- Implement access restrictions on assignments based on business rules or role based access controls.
- Process work objects as a user who does not have access to all of the work objects’ assignments.
Root Cause
A defect in Pega code/rules that results in assignment urgency synchronization updates which are attempted on assignments the user might not have access to.
Solution
Update to either of the following Pega Platform versions:
- Pega Platform 25.1.2
- Pega Platform 26
