Issue
The UX tab within the Case type option in Constellation applications returns the “Error in UI Authoring: Mismatch between View metadata and Template definition regions” error message under the following conditions:
The EnableCoexistence toggle is enabled when blending a traditional application within Constellation.
The traditional application is then migrated to Constellation.
Steps to reproduce
Create a traditional application.
Blend the traditional application to Constellation and set the EnableCoexistence toggle to fetch the required case types from the traditional application.
Migrate the traditional application to Constellation using the Constellation Modernization Assistant tool.
Root cause
The error in UI authoring occurs because the pyDetails view, saved in a custom class and ruleset, incorrectly uses the pyDetailsCoexistenceTemplate, which is only intended for traditional application blending within Constellation.
Solution
As a workaround, delete the custom pyDetails view for the classes specific to case type and use the work - class from the OOTB ruleset.
