Issue
After updating to Pega Platform™ 25.1.1 or decommissioning Hazelcast caching and clustering functionality, clients encounter OAuth token authorization errors.
Symptoms and Impact
Observed exceptions include:
Response 401 Unauthorized error occurred with new access token com.pega.platform.integrationcore.client.email.EmailClientException: The specified object was not found in the store., Default folder Root not found
Caused by: com.pega.platform.integrationcore.client.email.EmailClientException: Access is denied. Check credentials and try again.
Caused by: com.pega.pegarules.pub.PRRuntimeException: Failed while retrying to fetch accesstoken for clientID =
com.pega.pegarules.pub.services.OutboundMappingException: Could not acquire fresh access token -
Caused by: com.pega.pegarules.pub.PRRuntimeException: Unable to obtain access token for client details in authentication profile
configured for connector. Please check the logs for more details
Steps to Reproduce
Update deployment to Pega Platform '25.1.1 or otherwise remove/decommission Hazelcast from the deployment.
Leverage the same Client ID in Authentication Profiles meant for the same external OAuth client registration.
Root Cause
This is an implementation issue related to a token caching design change.
When decommissioning Hazelcast (which can be done from releases 23.1.4, 24.1.3 and 24.2) or when updating to Pega Platform ‘25.1.1, centralized token caching changes from a shared global cache to a node-local cache. There is a gap in how OAuth caches persist in the database.
Problems occur when multiple users share the same client ID, which is against best practices.
Using Hazelcast deployment/ Before upgrade (24.x)
- Hazelcast is used as a global cache, allowing all nodes to share OAuth tokens.
Tokens are consistently retrieved from the shared cache.
After upgrade (25.1.x)
Hazelcast is removed, and token caching becomes node-local.
If a token is not found in the local cache, Pega queries the database.
The database query filters tokens only by:
Client ID
Scope
Tenant ID
Operator ID
Username is not included, and there is no column to store it.
Impact of Current Design
When multiple users share the same client ID, multiple tokens may exist in the database.
The system may retrieve the first matching token, which could belong to a different user.
If the retrieved token does not correspond to the expected user, authentication failures will occur.
Local Change
Update to the following patch releases:
- Pega Infinity '24.2.5
- Pega Infinity 25.1.4
- Pega Infinity 26.1
Users on the following Pega Infinity releases can request a hotfix:
- Pega Platform release 25.1.2 - HFIX-D1621
- Pega Platform release 25.1.3 - HFIX-D1681
Solution
Replace the use of the OAuth password grant with a more secure grant type (for example, Authorization Code with PKCE or Client Credentials), as the password grant is deprecated and no longer considered secure.
Alternatively, configure a unique client ID per Authentication profile and user. If the same client ID is present in different authentication rules it can cause inconsistent product behavior, and this configuration will be blocked in future releases.
Follow these steps to configure a separate OAuth 2.0 Client IDs for each service account:
In Azure SPN, register separate client applications for each user.
Create separate Authentication Profile rules in Pega, each with its own ClientID.
Configure each integration/connector to use the appropriate authentication profile.
References
Configuring an OAuth 2.0 authentication profile
Removing Hazelcast from your deployment
Migrating from password credentials to modern OAuth 2.0 grant types
