Capgemini India Pvt. Ltd.
SE
WS-Security Certificate validation failed
We are facing an issue in our project when trying to set up WS-Security. A certificate chain is used here and the certificates are kept in the following way –
- The root and the intermediate certs are kept in the Pega truststore
- The client is signing the request using a leaf cert
The request is failing and we see the following error in the logs and in the response –
<soap:Fault>
<faultcode>wsse:FailedAuthentication</faultcode>
<faultstring>Certificate validation failed</faultstring>
</soap:Fault>
The application is running on Websphere 8.5.5.8
We have been able to replicate the issue using SOAP UI by following these steps –
1) Create 3 level key pair using keystore explorer.
A -- B (A) -- C(B)
2)Use this jks as keystore in SOAP UI.
3) Export certificates A.cer (root), B.cer (immediate), C.cer (leaf) fom keystore explorer.
4) Create a jks file and import B.cer into this. Use this jks file as truststore in the ws-security profile instance.
5) Use this ws-secuirty profile to enable web security for a SOAP service.
6) The web security configuration uses in-flow as below
Signature Algorithm -RSA-SHA1
Digest SHA256
Signature Key Identifier - Binary Security Token
7) Invoke the soap service from soap-ui using that keystore in outgoing WS-Secuirty configuration. Use B as alias so that the signature has to check certificate B
<soap:Fault>
</soap:Fault>
A -- B (A) -- C(B)
Digest SHA256
We raised an SR for this and got the following reply –
ROOT CAUSE
Issue with IBM WebSphere
RESOLUTION
Please follow the resolution IBM suggested in the following link.
http://www-01.ibm.com/support/docview.wss?uid=swg21651084
We have also tried this, but the issue did not resolve.
Has anyone faced this issue? If yes, then how did you resolve it?
Deepankar
