HCL Technologies Ltd
Last activity: 24 Jul 2018 3:01 EDT
Wrong data getting added/data mismatch when sorting on Grid Repeat Layout in 7.2.1
Wrong data is getting added/data mismatch is happening when sorting on Grid Repeat Layout in 7.2.1 when the grid is in editable mode.If the grid is in read only mode,the data is getting sorted in proper order. Please provide me a solution to fix this.
Thanks & Regards,
Anil
***Updated by moderator: Lochan to update platform capability***
Hi Anil,
Is there an error thrown on the screen when you say "wrong data added/data mismatch".
Add screenshots of the issue and how the grid is configured.
Evita.
Hi Evita,
Added the screenshots in the attached document. No error was thrown on the screen.
Please check below link. It may help.
https://collaborate.pega.com/question/incorrect-behavior-pxiseditable-rule-when-sorting-repeat-grid
CollabPartnerz
Please provide the screen shots how you have configured.
LTI Mindtree
Hi Anil
May I know what is the source for this repeating grid layout?
Hi Chaitanya,
Property is the data source to the Grid Repeat layout.And we called this section to another section.Attached the document.![]()
I did not get your question clearly. Are you facing issue with sorting with Editable Mode? Or you are adding data in editable mode and then clicking on sorting? Please clarify. Screenshots and detailed configuration will really help us.
Hi Rachit,
Facing issue with sorting with editable mode.
Are you modifying the data before doing the sorting?
nope
karthigeyan ravichandran
Vodafone
Can you share the screen shots of editable mode sorting and readonly grid and elobrate the issue. we can go through the configuration and get back to you.
attached the document with the screeshots
Vodafone
Hi Anil,
I don't see any mismatch in data behavior, I have tested the scenario in-house with both editable mode and readonly mode. For me the functionality works fine as expected.
Can you check in the Pagelist items and count in the clipboard.
