Chevron
Last activity: 22 Aug 2018 12:53 EDT
Where is the data from my data types in the case?
When I run my case I don't see the data inputed from the data types within the case in the case information section when setting it up for approval.
It is only for the sections in which I use a data types with multiple inputs, for instance, with my data type of contact information: email, name, address, etc.
I would like the approver to be able to view this information before approving. In addition, I want this information to all be stored in one place so that I can generate reports from it.
Any help would be greatly appreciated,
Thank you
FR
Chevron
Sorry, I'm not sure what you mean by my configuration. Could you please elaborate on where I can view my configuration?
Thank you,
Chevron
My pyWorkPage isn't showing when I goto clipboard and select my case. Do you know where it might be?
Tata Consultancy Services
Could you please provide snapshots of your Configuration and issue doc.
Chevron
Not sure what you're referring to, could you please explain?
Chevron
Here is a screen show of the setting for one of my data types. I'm not sure if this helps.
Not this one.
after submitting assighnemt data will be stored in work table, if you want hat data to be in any specified table then you nee dto write an activity to store that data.
if my understanding is wrong,please explain your scenario a bit clear.
Chevron
How do I access the work table? What I was wondering too is why when I run the case the case information only shows data inputs from the case and not the data from the data types that I have in the case.
I basically chose most of the default options when creating my case. Just wondering where I can view that information so I can use it for reports.
No need to access work table.
which information do you want to view, could you please elaborate.
Chevron
I have field groups in my case that are from data types. Such as contact information : Name, address, phone etc. Why are these not showing in my case information when it goes to getting approved and furthermore, where is it being stored? I would like to be able to view all of this in the case information section as well as storing all the information together.
I think we will need few screen shots to help you on this. Because your data could be anywhere really. It depends on your configuration. But I would say in general it should be under pyWorkPage somewhere
