What is the Data Set timeout/number of records threshold?
We have a data set present in a data flow which extracts data from a data type, and sends it to an Azure repository. It happens every 24 hours via a job scheduler. The data type has millions of data. Lately we are seeing the extraction is failing, its going to the repair flow with the error "ProblemFlow_InfiniteInnerLoop". When we are trying to run it manually, it times out.
The questions we have are:
- What are max number of records that can be exported via a data set?
- What is the timeout threshold of a data set export?
