NA
Last activity: 25 May 2016 16:24 EDT
What could be the possible reason for thousands of Scheduled items remaining in the Agent Queue on daily basis (SR-A24141)?
In our application we have configured a standard agent as shown below. On a daily basis we will be queuing 10000+ instances into the agent queue. It has been observed that, the instances are getting piled up in the scheduled queue, and no items are neither being moved to broken queue. Agent is being shown as running successfully. From logs, it has been observed that, service calls in the agent activity are getting failed. This is the only widely seen error in the logs. In this case atleast the instances should be moved to broken queue, but still not happening. Did anyone of you have ever faced this scenario? Request you to kindly provide your suggestions. We are using Pega PRPC 7.1.8
Note: SR-A24141 has been raised for this issue. Service Engineer advised to post the issue in this forum, to get expert advice.
Agent:
Scheduled Items:
Agent:
Scheduled Items:
Thanks & Regards,
S.Veera Vikram Reddy
NA
Hi Santanu,
Please find the below log with the error. I attached the full PegaRULES & Alert logs to the SR-A24141
2016-04-26 00:02:02,006 [.PRPCWorkManager : 6] [ STANDARD] [ ***********] ( internal.mgmt.Executable) ERROR Rule-Connect-SOAP.*********** - Exception
com.pega.pegarules.pub.services.RemoteApplicationException: SOAP service failed
at com.pegarules.generated.activity.ra_action_invokeaxis2_e0a499f26a95053ac6300b525bd7d41f.step15_circum0(ra_action_invokeaxis2_e0a499f26a95053ac6300b525bd7d41f.java:3994)
at com.pegarules.generated.activity.ra_action_invokeaxis2_e0a499f26a95053ac6300b525bd7d41f.perform(ra_action_invokeaxis2_e0a499f26a95053ac6300b525bd7d41f.java:308)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3500)
at com.pegarules.generated.activity.ra_action_invoke_c28ff8c27ac24045d30f5561679549d1.step8_circum0(ra_action_invoke_c28ff8c27ac24045d30f5561679549d1.java:1037)
at com.pegarules.generated.activity.ra_action_invoke_c28ff8c27ac24045d30f5561679549d1.perform(ra_action_invoke_c28ff8c27ac24045d30f5561679549d1.java:189)
Hi Santanu,
at com.pegarules.generated.activity.ra_action_******_256fcf1e9556cea99c69e4e87c09c7f3.step4_circum0(ra_action_getagentop_256fcf1e9556cea99c69e4e87c09c7f3.java:514)
at com.pegarules.generated.activity.ra_action__******__256fcf1e9556cea99c69e4e87c09c7f3.perform(ra_action_******_256fcf1e9556cea99c69e4e87c09c7f3.java:137)
at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10521)
at com.pegarules.generated.activity.ra_action__******__238f7a01a4ca276cbadc33e7ebbafcbc.step2_circum0(ra_action__******__238f7a01a4ca276cbadc33e7ebbafcbc.java:936)
at com.pegarules.generated.activity.ra_action__******__238f7a01a4ca276cbadc33e7ebbafcbc.perform(ra_action__******__238f7a01a4ca276cbadc33e7ebbafcbc.java:86)
at com.pegarules.generated.activity.ra_action__******__5aab21f92293cb443587e3bff0c46f62.step27_3_circum0(ra_action__******__5aab21f92293cb443587e3bff0c46f62.java:3229)
at com.pegarules.generated.activity.ra_action__******__5aab21f92293cb443587e3bff0c46f62.step27_0_circum0(ra_action__******__5aab21f92293cb443587e3bff0c46f62.java:3006)
at com.pegarules.generated.activity.ra_action__******__5aab21f92293cb443587e3bff0c46f62.perform(ra_action__******__5aab21f92293cb443587e3bff0c46f62.java:643)
at com.pegarules.generated.activity.ra_action__******__fd6932fb5c268e74d03fd95eeb5ec56f.step8_circum0(ra_action__******__fd6932fb5c268e74d03fd95eeb5ec56f.java:695)
at com.pegarules.generated.activity.ra_action__******__fd6932fb5c268e74d03fd95eeb5ec56f.perform(ra_action_mapantifraudproperties_fd6932fb5c268e74d03fd95eeb5ec56f.java:211)
at com.pegarules.generated.activity.ra_action__******__a698a6cf4e7694716bb30d04559488c8.step9_circum0(ra_action__******__a698a6cf4e7694716bb30d04559488c8.java:824)
at com.pegarules.generated.activity.ra_action__******__a698a6cf4e7694716bb30d04559488c8.perform(ra_action__******__a698a6cf4e7694716bb30d04559488c8.java:217)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.runActivity(QueueProcessor.java:721)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:602)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:945)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1259)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1008)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:901)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:670)
at com.pega.pegarules.session.internal.async.Agent.queueBatchActivityForAgent(Agent.java:1504)
at com.pega.pegarules.session.internal.async.Agent.queueBatchActivityForAgent(Agent.java:1293)
at com.pega.pegarules.session.internal.async.AgentQueue.run(AgentQueue.java:792)
at com.pega.pegarules.session.internal.async.Agent.runAgentTask(Agent.java:936)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.AsyncServant.processAsyncTask(AsyncServant.java:221)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.AsyncServant.invoke(AsyncServant.java:167)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:315)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:263)
at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.invokeEngine(EngineBean.java:225)
at sun.reflect.GeneratedMethodAccessor69.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:611)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:367)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:245)
at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.invokeEngine(EngineBeanBoot.java:168)
at com.pega.pegarules.internal.etier.interfaces.EJSLocalStatelessEngineBMT_f2439d86.invokeEngine(Unknown Source)
at com.pega.pegarules.session.internal.engineinterface.etier.mdb.PRAsync.processRequest(PRAsync.java:155)
at com.pega.pegarules.session.internal.engineinterface.etier.asynchbeans.AsyncTask.run(AsyncTask.java:64)
at com.pega.pegarules.session.internal.engineinterface.etier.asynchbeans.RunnableWrapper.run(RunnableWrapper.java:71)
at com.ibm.ws.asynchbeans.J2EEContext$RunProxy.run(J2EEContext.java:268)
at java.security.AccessController.doPrivileged(AccessController.java:273)
at com.ibm.ws.asynchbeans.J2EEContext.run(J2EEContext.java:768)
at com.ibm.ws.asynchbeans.WorkWithExecutionContextImpl.go(WorkWithExecutionContextImpl.java:222)
at com.ibm.ws.asynchbeans.ABWorkItemImpl.run(ABWorkItemImpl.java:159)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1646)
Caused by:
com.pega.apache.axis2.AxisFault: Exception occured while processing the request
at com.pega.apache.axis2.util.Utils.getInboundFaultFromMessageContext(Utils.java:531)
at com.pega.apache.axis2.description.OutInAxisOperationClient.handleResponse(OutInAxisOperation.java:375)
at com.pega.apache.axis2.description.OutInAxisOperationClient.send(OutInAxisOperation.java:421)
at com.pega.apache.axis2.description.OutInAxisOperationClient.executeImpl(OutInAxisOperation.java:229)
at com.pega.apache.axis2.client.OperationClient.execute(OperationClient.java:165)
at com.pegarules.generated.activity.ra_action_invokeaxis2_e0a499f26a95053ac6300b525bd7d41f.step14_circum0(ra_action_invokeaxis2_e0a499f26a95053ac6300b525bd7d41f.java:3891)
at com.pegarules.generated.activity.ra_action_invokeaxis2_e0a499f26a95053ac6300b525bd7d41f.perform(ra_action_invokeaxis2_e0a499f26a95053ac6300b525bd7d41f.java:291)
... 58 more
Also, it is a good idea to try tracing the agent .
You can review this PegaTube video to learn the technique on how to trace an agent, : https://collaborate.pega.com/discussion/video-support-guide-how-trace-agent-designer-studio
Thanks. Since there is already an SR I would leave this to the engineer who is working on this issue to take forward.
Meanwhile can you please update your post with the SR number
NA
To keep you informed, Service Engineer himself suggested to post this in this forum.
Hi Santanu,
I have shared him the below document on how the queueing will be done for the standard agents. In this case even though the exception has been entered in the log file for the SOAP call which is happening in the Agent Activity the unsuccessfully processed items are not getting moved into the broken queue.
https://docs-previous.pega.com/system-administration/how-agent-queues-work
Veera has informed that he will remove the SOAP calls from the Activity and will check. He is in a process of doing that. He is very curious to understand the actual working of the Standard Agent queueing mechanism practically instead of going through the document. Which is why i have suggested him to raise a community discussion for more exposure to the expertise like you.
Please let me know if you have any inputs for this.
Ravi
Hi Santanu,
One more thing i would like to add , as we know that the queued items will be processed in First in First out (FIFO). Veera would like to know is there any condition where this FIFO order would be skipped or not followed.
Please share your thoughts.
Ravi
Hi Ken Marin and Santanu Bhattacherjee,
I would also request you to let me know if we have any OOTB activity to re-process the items piled up in the queue.
Ravi
Hi Ravikiran,
For your queries :
1. He is very curious to understand the actual working of the Standard Agent queueing mechanism practically instead of going through the document
>> I believe , in order to understand the mechanism practically one needs to go thru the courses available in Pega Academy which generally comes with hands on example.
2. Veera would like to know is there any condition where this FIFO order would be skipped or not followed.
>> I am not aware of any such mechanism thru which you can skip the existing FIFO order .If you are using queue for agent method then probably playing with this can give some clue "MinimumAgeforProcessing "parameter. But not sure.
Others can comment.
We can re-queue the broken from place mentioned below.
Designer Studio --> Process & Rules --> Tools --> Work Admin --> Broken Queue items.
NA
Items are not moving to Broken-Queue they are accumulating in Scheduled Queue
Rabobank
I am thinking in some way.
If on a particular node where agent is enabled. But stopped in SMA.
So in that case agent will pick the item but attempt will be 0.
Can you check whether agent is active on all nodes in SMA.
NA
Agent is running property
HK
From the screen shot, there is no Class and Activity specified.
For Best Practice, also specify the Category dropdown.
Better to find another Queue to test your Agent b/c current Queue has too many items.
Hello
You said in the log, "service calls in the agent activity are getting failed ""
Can you please give more detail about the error you are seeing in the log.
If you can provide us the error snippet from log then it can help us to analyze further.
