What is the best way to create an application for the Organization layer?
There is a recommendation to create an application rule for each layer, which I find perfectly reasonable.
However, The new application wizard does not create an Org-layer application.
The Org-layer rulesets are part of the implementation-layer application.
So, what is the easiest or best way to "extract" these rulesets as part of their own application?
Do I have to Save As the Application, configure it and create any necessary Access Groups?
Or is there a simpler (or better) way of doing it?
If not, then what are all the settings that I need to change for the Org-layer application?
I could think of the following:
1. Skin
2. Associated classes
For the Access Group:
1. set the Design-time config to the Org-layer ruleset
2. create and use a new work pool
3. create and use a new Org:Administrator role
Is there anything I miss, or any document that describes all the necessary stte
