Way / Method to extract Pega clipboard using java code.
Hello there,
As a part of my project requirement I am looking for a way / method to pull out extract from pega clipboard using java code.
In a centralize infra will have java code encapsulated in a jar and based on a config file which will have primary id which may be a case id the code would do handshake with Pega clipboard and fill out other details in the csv.
To achieve above I am looking for an API / method / solution if some one has implemented in their project / work.
Any pointers which can help me to solve above stuff will be helpful.
Thank You,
Kapil Chandak
***Updated by Moderator: Vidyaranjan. Removed user added Ask the Expert tag. Apologies for confusion, shouldn't have been an end-user option***
