i want to open object using custome java code. anyone know how to do that
i want to open object using costume java code. anyone know how to do that
Try adding an activity steps when you call an Obj-Open-By-Handle, and save it.
You can then examine the java code that it generated. But this java code would only work if called in Pega.
You can see the generated Java code of activity using "View Java" in actions menu of activity.
SamplePage = tools.getDatabase().open(SamplePage, false);
You need to create the clipboard page with name SamplePage and set the necessary values for the keys.
