Vertical alignment of sections included into repeating grid layouts
Dear all,
we are facing some issues regarding the vertical alignment of different UI components while including a section into a repeating grid cell.
The scenario is as follows, please also find the attached screenshot which I have drafted to indicate how the real issue looks like:
There is a section, lets call it "OuterSection" including a repeating grid layout. This repeating grid layout holds different kind of columns:
- some columns hold a simple Text Input" field. Vertical alignment is fine for these fields (marked in green in the attached screenshot).
- one column of the repeating grid layout includes another section "InnerSection1" which is supposed to reveal only one label based on certain visibility conditions. The vertical alignment of this field is just horrible irregardless of any layout option I have tried within the InnerSection1 settings (marked in red in the attached screenshot)
- one column of the repeating grid layout includes another section "InnerSection2" which is supposed to reveal certain "Text Input" fields in read only mode. The vertical alignment of these values is more ore less acceptable but still not fine. This is irregardless of any layout option I have tried within InnerSection2 settings (marked in yellow in the attached screenshot).
The same strange layout is also applied when we include a section holding a dropdown field.
Dear all,
Is there any way to assure proper vertical alignment for this scenario?
Thanks a lot for all your efforts and responses!
Cheers,
Stefan
