v8.7 confusion of the use of embedded kafka, cassandra/support
87_PlatformSupportGuide_Jan2022.pdf - below is mentioned in the doc.
1. Beginning in Pega Platform version 8.6, when you are setting up new environments, you are encouraged to use an external Cassandra database instead of the embedded version
In Pega Platform version 8.6, deployments using embedded Cassandra are deprecated, but will still work. Future versions of Pega Platform will no longer support deployments on embedded Cassandra.
To ensure future compatibility, do not create any new installations using embedded Cassandra.
For information about how to configure Pega Platform to access an external database, see Defining Pega Platform access to an external Cassandra database.
2. Same with embedded kafka in the 8.7 release note - https://docs-previous.pega.com/platform-release-notes/87/platform-87-release-notes
Questions:
1. For earlier version that are currently using embedded Cassadran and Kafka, is it a pre-requisite to provision External Cassandra and External Kafka?
2. what is going to happen if the client does not have the Cassandra and Kafka server set up
3. is the stream nodetype still be there but for internal use?
If no more embedded Kafka, how would this impact QP and Search Indexing that are currently using stream node?
4. is the DDS nodetype still be there but for internal use?
Questions:
If no embedded Cassandra, how would this impact ADM and DSM that are currently using embedded Cassandra?
