ASM
ID
Last activity: 20 Feb 2025 4:56 EST
Using JAVA Statement To Connect to a DB Based on Registered DB Instance
Hi, I am currently learning how to code to connect to an OracleDB Via Java Activity.
Currently I have an already configured connection named WARRANTYX in my Database instances, and I want to connect based on that connection name. It already has the JDBC URL, Username and Password configured.
How do I do so so I can execute the codes below to retrieve the datas from WARRANTYX:
java.sql.PreparedStatement cs= Conn.prepareStatement("SELECT QUERY HERE");
java.sql.ResultSet result = cs.executeQuery();
Thanks in advance
