Using Declared Index Table for a different class or as a class join
I need to be able to use the records in a Declared-Index table as either an index join or class join, obviously, Pega is preventing such usage.
The scenario is as follows:
I have a Pagelist within a Work- class that indicate who have access to this case, this is dynamic and selected and changed anytime the user desired.
A DI is created to flatten this into a corresponding table.
In the Assign-Worklist, I want to get a list of workitems that the current user have access to, based on the assignment as well as the Pagelist info (output thru a DI).
However, I am not allowed to do a Index Join to the Assign-Worklist because this is an index belonging to the Work-, not Assign-.
I am also not allowed to use this DI table as a class join to Assign-Worklist, as Pega does not allow me to map the corresponding keys from both tables.
Could anyone advise how I could use the RD to get a list of relevant workitems that a given user has access to based on the Pagelist defined above?
Using row Visibility is an option, but I hope to get the list from RD directly.
I am also trying to avoid RDB related stuff too.
Thanks and looking forward to any advice.
Jacky
