upgraded one node from 8.6.2 to 8.71 and can't start node
1- After upgrading one of the node from 8.6.2 to 8.7.1 we are getting below exception
2022-05-18 16:00:17,830 [StreamServer.Default] [ STANDARD] [ ] [ ] (rvice.operation.StartOperation) ERROR - Cannot start service [StreamServer.Default]. Will retry in 180 seconds. Remaining attempts: 0 org.jboss.netty.channel.ChannelException: Failed to bind to: /127.0.0.1:2181
i have added below 4 configuration in prconfig.xml
<env name="cluster/hazelcast/v4/enabled" value="true" /> <env name="dsm/services/stream/pyJmxPort" value="10900" /> <env name="dsm/services/stream/pyBrokerPort" value="19892" /> <env name="dsm/services/stream/pyKeeperPort" value="12181" /> <env name="dsm/services/stream/pyPort" value="39403" />
Now i'm getting below Error
2022-05-19 00:27:31,342 [StreamServer.Default] [ STANDARD] [ ] [ ] (rvice.operation.StartOperation) ERROR - Cannot start service [StreamServer.Default]. Will retry in 180 seconds. Remaining attempts: 0 com.pega.dsm.dnode.api.StreamServiceException: Cannot add new node. Make sure all listed nodes are available or reattach the volume from one of these nodes to this node. [Node=e600df2eabb336b65df2f59a1225900d, broker=1001 Node=273a9b0b116b984c59f4540bdb1624cb, broker=1002]
