Upgrade Hazelcast in Pega 8.8.1
Hi ,
we started seeing the below information in logs about Hazelcast version is not supported and suggest to switch to v5 but How do we switch to v5 ? Just updating the setting in prconfig file is sufficient ? (or) do we need to import any jar files for Hazelcast ?.We are on 8.8.1 and using embedded Hazelcast.
Infinity is using Hazelcast Enterprise 4.2.4 for clustering. This version of Hazelcast is not supported anymore. Please set the prconfig setting 'cluster/hazelcast/v5/enabled=true' to switch to Hazelcast Enterprise 5.1.1 . Refer Admin Guide for more details.
@BRAHMESH@
for previous version with same kind of error message for hazelcast V4 it was fine setting the below line inf prconfig
<env name="cluster/hazelcast/v4/enabled" value="true" />
Seems to be same here, yet with V5.
It's worth a try :)
Regards
Anthony
