Last activity: 26 Sep 2018 1:29 EDT
Unwanted log messages in Robotics Runtime Log
Hi Team,
We are getting the below unwanted error entries in Runtime Log. Though they are not related to any application issues, they will generate a bunch of service desk tickets for one of our clients which is cumbersome to clean up.
I have tried and even a bare minimum robotics project seems to generate the below errors in log.
Can you let me know how to get rid of those issues. Thanks!
Error | 08:14:54.194 AM | 1 | STA | AutomationBroker | | | AutomationBrokerServicesFactory not found
Error | 08:14:54.853 AM | 4 | MTA | ApplicationFramework | | | Error parsing StartMyDay section of RuntimeConfig. 'FileLocation' section has missing or empty 'value' attribute.
Error | 08:14:55.116 AM | 4 | MTA | Runtime Application | | | Error reading Shutdown setting. Unexpected Setting: ''
In the RuntimeConfig you may control the LogLevel by the Category as mentioned earlier. If you set the LogLevel to 0 for the categories that you want to suppress they should not log.
For the errors you are seeing, do you have the AutomationBroker Factory in your solution? If so, you should be able to remove it or disable it. The second error relates to the StartMyDay setting in your RuntimeConfig. Update the FileLocation key and that should go away. The third one would require looking at your solution and how shutdown is happening.
Lastly, items with the Error MsgType are not what I would generate tickets from. Exceptions are real issues that require attention. Error is a classification that is used throughout the product to ensure you have visibility to these issues with reduced logging. This is not an indication that there is an issue with your solution by default.
