unit test when rules tied to a declare expression
We have a lot of Delcare expressions tied to a When rule, both the DE and When rule is created and maintained by the business. What is the best way to unit test this. Tried testing it by copying a test page and also a data transform and they return null bcos the DE fires which fires a declare page and since the input etc .. is not there, the data is not present and the result of the expression is NULL. Is there a switch to turn off firing declaratives so an expression like
Value of A/B > C where A and B have DEs tied to it can be supressed and the values in the transform or the page used.
Please share your thoughts, we are using version 7.2.2
