TCS
Unable to read window's control properties
When interrogating a windows application, it's recognized as a "control". The control's native name is "00090766 "" Afx:00400000:8:00010005:00000000:00000000". We are trying to read text value of this control via "GetText" or any such available properties / methods but unable to get the value of it.
Can you help letting us know if there is a way to read the actual text that's populated within this control?
Thanks again..
If all you need is the text, then you should be able to use a control region.
http://help.openspan.com/80/Adapters_Interrogation/Add_Control_Regions_Windows_Tab_Functions.htm
