Unable to perform any action on the case
Hi everyone,
We're encountering an issue in our production environment where the pyWorkPage is embedded within a pagelist property. In one instance, the pyWorkPage is embedded inside the pxStageHistory pagelist, which we don't update in our application.
When attempting to click on the pyWorkPage from the clipboard, the system becomes unresponsive. I can expand the pyWorkPage and inspect other embedded pages.
I've tried to use Obj-Open-By-Handle on the case, but the step doesn't complete, and the activity ends abruptly.
I'm seeking advice on potential workarounds to remove the pagelist where the pyWorkPage is embedded and successfully save the case. Has anyone encountered a similar situation or can suggest a solution?
Any insights or recommendations would be greatly appreciated. Thank you in advance for your help!
