Ford Motor Pvt Ltd.
Last activity: 31 Dec 2020 0:13 EST
Unable to get case properties while configuring Robot Activity in Robotics
In Pega 8.5.1, I have configured Case data model with a couple of properties. But while I am trying to configure Robot Activity in Robotics, I have mapped class, Username, Password. But in result I get only a blank box. It doesn't return the case fields there.
Also tried, to check in Application->Inventory->Relevant Records. Even there it lists out only the flows in that class. There also it doesn't list out the case fields.
Please help! if someone is able to achieve it.
Hi Vikas,
Please mark the properties as relevant records for the class where the case type is created. Only then the properties will be available. If you had used App Studio then Pega would have automatically marked the properties as relevant records
