Accenture
Last activity: 7 Jun 2021 0:35 EDT
Unable to establish successful connection with Kafka broker
I have set up a local kafka server with SSL enabled one side and SASL enabled for client authentication. Configuration is done on the server side. Please find attached the server.propeties and zookeeper.properties file. Since i cant attach properties file in support site, im attaching it in txt format here.
Below are the lines added in server.properties file. its added in the last
sasl.enabled.mechanisms=SCRAM-SHA-512
sasl.mechanism.inter.broker.protocol=SCRAM-SHA-512
listener.name.sasl_ssl.scram-sha-512.sasl.jaas.config=org.apache.kafka.common.security.scram.ScramLoginModule required username="broker-admin" password="DEM123";
super.users=User:broker-admin
authorizer.class.name=kafka.security.authorizer.AclAuthorizer
How to set up the configuration on the pega side? I see the below in the docs but this is not clear.
Before you begin:
In systems deployed on premises, Pega supports configuring SASL authentication between Pega Platform and the Kafka cluster using a JAAS configuration file. To configure SASL authentication, perform the following steps:
Before you begin:
- In the Kafka cluster, configure the Kafka Client credentials in the JAAS configuration file to enable either simple authentication (using a username and password) or Kerberos authentication. - JAAS Config file is attached in the txt format , is that fine?
- Pass the location of the JAAS configuration file as a JVM parameter in the Kafka cluster, for example: -Djava.security.auth.login.config = <path_to_JAAS_file> - In which file should i put this into?
For more information about configuring the JAAS configuration file, see the Apache Kafka documentation.
Please help me on this.
