Unable to access/view the available events for the CRMfromLogin when adding automation logic for Openspan.
I am currently doing "Windows Integration" of OpenSpan Studio Core Training. I in - Chapter 7: WORKING WITH OPENSPAN AUTOMATIONS. In that now I am doing Group Exercise 2, where I am able to select the CRMfrmLogin control but after that not able to perform the following steps as I am not seeing the relevant icons.
2. In Object Inspector, click the Show Events Only icon. The available events for the CRMfrmLogin control appear. You need to use the Created event for this automation............................
3. Click the Configure Type icon to display the Form Configuration dialog. To quickly locate the event, you can use the Filter field and enter Created. Expand Events, check Created, and click OK to add the.....................
4. In the Events section, select the Created event and drag and drop to the CRM_E_CRMfrmLogin_Created automation.
Below the Object Explorer I am just getting a properties for window. Can you please let know how to display the configure window or get the icons relevant here.
***Updated by moderator: Lochan to move post from PSC to Pega Academy***
